Date/Time: Tue, 15 Apr 2025 14:37:57 +0000
Any way to get study calculation time across all studies on every chart in a chartbook?
View Count: 230
[2024-10-14 15:11:14] |
User625505 - Posts: 6 |
I searched around before asking, hopefully not a question that has been asked. But is there a way to see a consolidated list of all of the studies in a chart book, for all charts, and see details - mainly the calculation time? I have quite a bit of charts per chartbook and should probably just create more instances but I would like to see if I can find the problem studies and either update the amount of data they are calculating or remove them...if I would just need to create a ASCIL study to pull this info please let me know! Thanks |
[2024-10-14 17:03:49] |
John - SC Support - Posts: 39275 |
There is not a consolidated place for all the information. But the information for the length of time for a study to calculate is on the "Analysis >> Studies" window. So you can view this for each chart on that window. Also refer to the following: Chart Studies: Reducing Processing Time for Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-14 17:17:40] |
Thanks - sometimes it can be difficult to look at that window since you can't resize it and see all the info. I assume there's not a value that can be pulled using custom programming? No worries if there's not, I will have to take the time and go through all of the studies then. Thanks |
[2024-10-14 17:30:57] |
The calculation time for other studies is not available through ACSIL, just the time for the last calculation of the actual ACSIL study itself is available.
[2025-03-29 01:17:09] |
drinkcodejava - Posts: 24 |
Hi John, from your link (Chart Studies: Reducing Processing Time for Studies): Initially when a study is added to the chart, a chart is recalculated, or a chart is loaded or reloaded, there is a full recalculation of the study. Thereafter, there is only an update calculation which is very efficient. The update calculation, is an negligible amount of processing.
When I read this page (Working with ACSIL Arrays and Understanding Looping: When the Study Function is Called), it differentiates between Full Calculation/Recalculations and Update Study Function Calls. 1) I assume these two pages are referring to the same two types of study calculations, correct? 2) Is the ms number listed the Analysis >> Studies list the duration of the last Full Calculation/Recalculation (and not an Update)? I am working on reducing the calculation time of a custom study, and I want to make sure I understand the terminology in the documentation correctly. Thank you! EDIT: Please disregard. I was able to find the answer on Chart Studies: Chart Studies Window The value in the Chart studies window list is the last Full Recalculation value. Date Time Of Last Edit: 2025-03-29 16:14:41
