Date/Time: Wed, 27 Nov 2024 12:58:59 +0000
How it is possible? Different candle for one day - nonsense
View Count: 849
[2014-09-05 16:26:18] |
Sam33 - Posts: 12 |
Hi, could you please check the attached file. I´m backtesting YM. I changed the date for these 2 charts from 2013-04-30-2014-05-14 to 2013-04-30-2014-05-13. The difference of the candle from 2014-05-13 is illogical. What can I do with this mistake? Thank you very much for your reply Ing. Jiri Samuel |
How it is possible 2014_05_13.doc - Attached On 2014-09-05 16:16:44 UTC - Size: 642.5 KB - 350 views Attachment Deleted. |
[2014-09-05 23:27:00] |
We will only accept chart images, that are posted by using this method here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image DOC files are not acceptable to us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
