Date/Time: Fri, 22 Nov 2024 10:23:23 +0000
Incorrect Data on DOM vs Trade Activity Log
View Count: 98
[2024-10-14 14:44:53]
L2Ltrades - Posts: 60
Please see the attached images. The P/L on the DOM is different that on R-trader Pro and in Sierra Charts trade activity log. The DOM has been set to account for the P/L including the commissions. Please assist.
imageCapture.PNG / V - Attached On 2024-10-14 14:44:32 UTC - Size: 116.48 KB - 21 views
imageCapture1.PNG / V - Attached On 2024-10-14 14:44:42 UTC - Size: 216.51 KB - 20 views
[2024-10-14 17:00:34]
John - SC Support - Posts: 36203
In order to ensure that the "Daily Profit/Loss" shown on the Trade Window matches the amount on your Trade Activity Log, you need to ensure that the "Chart >> Chart Settings >> Trade >> Order Fills Start Date/Time" fields are set to show the same time period as your Trade Activity Log. Otherwise, the fills that make up certain orders may not be included in the Daily Profit/Loss for the trade window, as the chart is not including them. Refer to the following:
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
Once you have the above worked out, then you would need to look at your trades in relation to what Rithmic shows to determine why there is a difference between them. The main item to check on is that the Commissions are the same between the systems.
