Date/Time: Thu, 31 Oct 2024 10:12:41 +0000
PREVIOUS DAY OHLC
View Count: 141
[2024-10-14 06:47:22] |
User581066 - Posts: 22 |
Hi, is there a way to display on my chart the previous day ONLY OHLC and not the days before Brothers the current day OHLC. I just want the previous day OHLC to be displayed on my chart
[2024-10-14 16:21:43] |
John - SC Support - Posts: 35639 |
Use the "Daily OHLC" study and set the following specific inputs: - Reference Days Back: 1 - Days to Calculate: 1 Refer to the following: Daily OHLC: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-14 16:22:06
[2024-10-16 18:57:19] |
Hi Thanks it worked but now i have another issue. I set up OHLC for a source chart,but when I use and set up the overlay study on the dom the OHLC that i can see on my source chart doesnt appear on the DOM. Note that my dom sesssion time is différent than the source ´ chart session time. What is weird is that i was able to see the OHLc on my dom this morning, Then I connected back a few hours after and the OHLC just doesnt appear anymore while i can still see it on the Source chart. |
[2024-10-16 19:37:51] |
The most probable answer is that the lines are there, but at are levels that you can not see in your Trading DOM, particularly since you are looking at the previous days data. Change the range of the data in the Trading DOM to ensure the prices at which those lines exist are shown. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-16 21:05:16] |
My source chart is showing 70.06 as Low, this level identified with the « High/Low for time period ». When I scroll to 70.06 with the DOM and after using the overlay study on the dom, this level (70.06) is not marked. Note that other levels related to other studies from source chart are marked on the dom. But the Overlay study that uses the study « High/Low for time period » doesnt show on the Dom. |
[2024-10-16 22:19:42] |
Please get us that chartbook so we can take a look, by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-17 00:00:26] |
Source chart is the 60min chart #20 At the time i am writing this (7.30pm EST) the study “2 ID:6 OVERN(LONDON)” is visible on the source chart and I can see the levels marked. But the levels are not displayed on the DO even after using the overlay study. Date Time Of Last Edit: 2024-10-17 00:01:05
Private File |
[2024-10-17 13:42:12] |
For us, right now at 08:41 Central US time, the DOM is showing the data for the London High/Low just fine. We will take a look at this later in the day and see if it disappears. About what time do this occur for you?
[2024-10-17 15:04:58] |
This occured at 7.30 pm EST time. Also try for the asian High and Low, i wasnt able to see them Today at 8.50am EST but was able to see them yesterday at 7.30 PM est Same thing for the Asian overlay study. It work during some time of the day ( Around 7.30pm EST) and nor work during other Times (8.30 am EST) |
[2024-10-17 15:53:18] |
The reason for the issue is that the Trading DOM does not have the same concept of bars as a regular chart. So since the study you were using had an end time of "08:55:55" the data is not present at the most recent bar, therefore the Trading DOM is not able to pick up the information properly. The solution to this is to use the "High/Low for Time Period - Extended" and have the data extended through the end of the day. This way, the Trading DOM will have access to the latest bar and will there display the Name and/or Value labels as you want in the Trading DOM. Refer to the following: High/Low for Time Period - Extended For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
