Date/Time: Fri, 22 Nov 2024 10:48:04 +0000
FED FUNDS Futures CME Group Data - Quote Spreadsheet
View Count: 92
[2024-10-13 06:30:48]
eaglefutures - Posts: 48
hello Sierra team
I am picking up an issue on the Fed Funds symbols, these plot in a normal chart , so the data is coming through example symbol
ZQM25_FUT_CME
However if this same symbol is added to a quote spreadsheet, then the data does not populate the spreadsheet.
Then for none of the symbols does the OPEN INTEREST Field populate
Is there something else I should do ?
[2024-10-14 15:29:21]
John - SC Support - Posts: 36203
We are not seeing any issue with the Quote Spreadsheet (or the Quote Board) for the ZQM25 instrument.
Are you able to get data for more current, and more traded, instruments such as ESZ24_FUT_CME?
Also, please try the Quote Board and see if you have a problem with the instruments on the Quote Board as well.
[2024-10-14 17:02:31]
Hi John
Seems to be working now. I did not change anything though. Could be a weekend maintenance issue maybe when they upgrade servers or something
[2024-10-14 17:26:11]
We do not know. We are glad it is working for you now however.
