Date/Time: Wed, 27 Nov 2024 12:31:03 +0000
How do I figure out my license key?
View Count: 1382
[2014-09-05 16:16:42]
ZGerenstein - Posts: 6
[2014-09-05 17:39:15]
Sierra Chart does not use license keys. You log into Sierra Chart with your Sierra Chart Account Name and Password.
What is the specific problem you are having? We see you have successfully installed and logged into Sierra Chart.
[2014-09-05 17:46:10]
I recently received chartbooks from a professional trader that sells them, indicators, alerts, etc. and he says he needs a license key to activate them...
[2014-09-05 18:13:18]
That is not the correct term. They should not be using the term "license key" because Sierra Chart has no license key.
They probably are referring to your Account Name which you can find under Help >> About.
