Date/Time: Fri, 22 Nov 2024 10:25:06 +0000
Force Index
View Count: 115
[2024-10-12 18:45:33]
User763335 - Posts: 82
Hi
I see this study has no user inputs. Can I know over what period(length) are you calculating this as default?
And can the length be added as a user input for this indicator?
[2024-10-14 14:42:09]
John - SC Support - Posts: 36203
There is no periodicity for this study. The formula is the following:
FI_t = V_t(C_t - C_{t - 1})
Where FI_t is the Force Index at bar t, V_t is the Volume at bar t, C_t is the Close value at bar t, and C_{t-1} is the Close of the bar at t-1 (previous bar).
You can view the information and formula for this at the following link:
Force Index
[2024-10-14 22:11:58]
Thanks, found an alternative.
