Date/Time: Fri, 22 Nov 2024 04:57:58 +0000
Read Symbol Name - Chart Drawing Alert
View Count: 120
[2024-10-12 15:51:09] |
Benutzer4711 - Posts: 35 |
Hello, can you please check about the option to read the symbol name when a chart drawing alert is active. [ ] read symbol name - then play alert [ ] read only symbol name I have attached a screenshot for better understanding. Symbol reading should be cut off when a . or _ comes after the first letters, since the exchange is not mandatory imo. I'm assuming its possible since Sierra has the text reading alert function already implemented: In the General Settings -> Alerts section, an option to "Text to Play when this Alert Triggered" is available. So a Text can be played without creating sound files. |
Symbol_Alert_Option.jpg / V - Attached On 2024-10-12 15:44:37 UTC - Size: 1.25 MB - 39 views Attachment Deleted. |
[2024-10-15 16:59:48] |
Hello?
[2024-10-15 18:08:03] |
John - SC Support - Posts: 36203 |
This has been set as a Feature Request. We generally do not respond to Feature Requests.
[2024-10-16 11:27:12] |
Thank You!! worlds best software - imo ! |
[2024-10-16 15:37:24] |
Thank you. We appreciate that.
