Date/Time: Fri, 18 Sep 2026 01:58:01 +0000
Chartbook
View Count: 448
| [2024-10-11 18:45:01] |
| KevinDiard - Posts: 22 |
Hello, when I open a second chartbook after my main chartbook, I always have windows from chartbook 1 mixing with chartbook 2 or vice versa... How can I make sure my chartbooks have the right windows? Thanks |
| [2024-10-11 18:47:27] |
| John - SC Support - Posts: 47930 |
In general, when you are viewing a Chartbook, you are only able to view the windows (charts, spreadsheets, etc.) that are associated with that single chartbook that is open. The one way around this is to select the option for "Window >> Window Always Visible". This makes it so a specific window will still be visible when you change to a different chartbook. Therefore, you must have this option enabled for those windows that are visible from Chartbook 1 when you are viewing Chartbook 2. You would have to go through and set each window to not have that option enabled. Refer to the following: Window, CB and CW Menus: Window Always Visible (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
