Date/Time: Wed, 27 Nov 2024 12:35:06 +0000
Does Sierra Chart Work with FIX API
View Count: 1418
[2014-09-05 16:09:17]
User88192 - Posts: 2
I have a trading account which provides a FIX API connection. The account is not currenex, my question is does your software work with 3rd party FIX API 4.4 protocol?
[2014-09-05 16:44:29]
It looks like FXCM uses the same FIX API 4.4 as Gain GTX - could I use the FXCM setting to stream/get data from the GTX API? If not, is there any way to add a custom FIX API connnection?
[2014-09-05 17:36:09]
This will not work. FIX is not an exact standard for this to be possible.
It is not possible to add a custom FIX API connection.
