Date/Time: Tue, 22 Apr 2025 14:35:28 +0000
[User Discussion] - Difference Display for P/L on Trade Activity tabs
View Count: 212
[2024-10-11 12:40:39] |
User226957 - Posts: 11 |
Hello, I only placed two trades this morning one to buy and another to sell futures contacts that resulted in a profit of $350. But, I am seeing different amounts on the Trading Activity Log>Chart Stats (Daily P/L $350) and Statistics tabs (Closed Trades Profit/Loss). Even if i perform more trades, the difference in the P/L is x 10 between both of the values. Can you please assist with resolving this issue? Date Time Of Last Edit: 2024-10-11 12:56:08
[2024-10-16 22:27:59] |
Sierra_Chart Engineering - Posts: 19305 |
Is the profit/loss value correct in the Trade Activity Log? Is it incorrect in the chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-16 22:28:34
[2025-01-13 21:19:05] |
Hello, I apologize for the delay in response. But, I didn't find a profit/loss value in the Trade Activity tab. But, the Trades tab does show a profit/loss value, which does match the profit/loss value in the Statistics tab. |
[2025-01-16 01:48:55] |
If there is an issue with the Daily Profit/Loss display in a chart, refer to: Help With Daily Profit/Loss Value Also refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
