Date/Time: Mon, 28 Oct 2024 08:57:40 +0000
Nothing is drawn on a small volume
View Count: 89
[2024-10-11 09:52:55] |
SkyKeeper - Posts: 40 |
Hi. When drawing a volume in new versions, nothing is drawn on a small volume. It can be fixed as it was in earlier versions. For example, in version 2656 everything worked, but in new versions it is not displayed! |
[2024-10-12 00:38:37] |
Sierra_Chart Engineering - Posts: 16755 |
Does not make much sense this is a version specific issue. Nothing has changed with this. We need to get that chart, by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
