Date/Time: Tue, 15 Sep 2026 13:50:44 +0000
Questions about the version of Sierra Chart
View Count: 518
| [2024-10-11 05:01:50] |
| User886314 - Posts: 24 |
Hi Engineer, I would like to know if Sierra Chart can be opened more than one account at the same time if I'm in a self-employed trading studio? Or is there a Sierra Chart trader version? I would like to know
| [2024-10-11 14:21:54] |
| John - SC Support - Posts: 47889 |
We do not have a "trader version". We are not understanding the question of "if Sierra Chart can be opened more than one account at the same time". Can you please give us more detail on exactly what you want to accomplish. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-10-11 17:38:37] |
| ForgivingComputers.com - Posts: 1238 |
Not sure if this answers your question, but it is usually one account per instance. If the accounts are at different brokers, then they must be in different instances. If they are at the same broker (e.g. with IB) then you can trade in the same instance using different accounts on different charts. The Trade Copier feature will only work within a single instance. |
| [2024-10-11 18:38:04] |
Hi, maybe I didn't express myself very clearly, the question I want to ask is if I have a sierra chart account of my own, can other people use my sierra chart account at the same time?
| [2024-10-11 19:06:48] |
Officially - No. Refer to the following: Sierra Chart Purchase and License Information: Licensing / Number of Systems For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
