Date/Time: Mon, 28 Oct 2024 08:57:41 +0000
Import chart into another SC install chartbook
View Count: 70
[2024-10-10 17:40:52] |
nwills - Posts: 13 |
I have created a custom DOM in a chartbook. I would like to import that DOM into another chartbook that is in a separate SC install. Is this possible and if so how? Thanks |
[2024-10-10 18:55:40] |
John - SC Support - Posts: 35538 |
To do this do the following: - Save that Chartbook that has the customized DOM in it. - Copy that Chartbook to the other installation. Be careful with chartbook names to ensure that you do not override an existing chartbook - Open that chartbook in the new instance. - Use the "Chart >> Duplicate Chart to Chartbook" to get that one chart (DOM) to the chartbook you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-10 19:05:09] |
It seems that there are no other chartbooks (other than the one open) available in the duplicate chart to another chartbook window list.
[2024-10-10 19:17:30] |
Sorry, didn't have both chartbooks open. Problem solved. Thanks
