Date/Time: Wed, 27 Nov 2024 13:02:19 +0000
SCSS Spreadsheet problems
View Count: 1131
[2014-09-05 14:15:17] |
djcurcio - Posts: 236 |
Yesterday I had to upgrade my Transact software to Version 1 5.6.6.4 and that did an automatic conversion of my multiple Spreadsheets alerts to .scss. This has damaged many formulas, whacked the formatting, changed the fonts, put a red triangle in every cell (whatever that means), does not seem to know how to put a $ in dollar fields, and does not allow for copying formulas, formatting and values into a range of cells, and eliminating all of my previous conditional formatting. This is really ugly. How to fix this mess> Help please. |
[2014-09-05 14:57:50] |
You need to select Help >> Download Prerelease (Old Spreadsheets). Once the download and installation is completed, then this will automatically solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
