Date/Time: Fri, 22 Nov 2024 11:22:36 +0000
Trying to Enable Auto Trading for Live
View Count: 124
[2024-10-10 13:57:08] |
Le Dharma - Posts: 73 |
Hey Sierra. I have an Auto Trading tool for trade placement. The auto Trading tool works exactly as designed, for Sim trading. However, the Tool does not work for Live Trading. When Auto Trading is enabled for everything, The Spreadsheet for Automated Trading will work - for Sim only. When I set Sierra trading to Live, the Spreadsheet does not initiate any trades. Can you guys help? Date Time Of Last Edit: 2024-10-10 13:57:32
[2024-10-10 14:42:17] |
Hey Sierra, Here's a snapshot of my Spreadsheet Settings
AutoMated Entry Tool - Spreadsheet System for Trading 2.png / V - Attached On 2024-10-10 14:41:28 UTC - Size: 143.12 KB - 28 views AutoMated Entry Tool - Spreadsheet System for Trading.png / V - Attached On 2024-10-10 14:41:35 UTC - Size: 127.24 KB - 25 views Attachment Deleted. |
[2024-10-10 15:42:06] |
John - SC Support - Posts: 36203 |
The most likely reason is the Input on the Spreadsheet System for Trading for "Send Orders To Trade Service" is not set properly. You need to change this depending on whether you are working in Simulation Mode or sending to a live trading account. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Send Orders To Trade Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
