Date/Time: Fri, 22 Nov 2024 11:01:01 +0000
Line to connect points
View Count: 95
[2024-10-10 13:13:51]
Lilydo - Posts: 14
I'm using Color Bar base on condition to set up Red points and Green points. Do you know which study to automatically drawn a line to connect red points if red point [-1] is lower than red point or green point [-1] is higher than green point.
On the picture, I draw by hand.
Lily
Private File
[2024-10-10 15:28:40]
John - SC Support - Posts: 36203
This is one of these things that is easy for a human, but hard for a computer. You might be able to get a Spreadsheet Study setup to do this, but we do not know for sure, it would take a fair amount of manipulation.
It would definitely be easier to create a custom study, or have someone create one for you. Refer to the following:
How to Build an Advanced Custom Study from Source Code
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
