Date/Time: Fri, 22 Nov 2024 11:01:03 +0000
i can not load more than 30 days of intraday data
View Count: 109
[2024-10-10 13:04:19] |
User685750 - Posts: 1 |
Hello, i am having trouble loading more than 30 days of intraday data i tried changing the number of days to load in settings but it does not change anything, i even tried updating SC and deleting and re-downloading data but it still does not work. is it because i am on a free trial ? thank you in advance here is an image of the chart if you look at the first days they are condensed : https://www.sierrachart.com/image.php?Image=1728565049739.png |
[2024-10-10 15:07:49] |
John - SC Support - Posts: 36203 |
You are limited to 10 days of Intraday data while on a trial. Refer to the following: Sierra Chart Trial Account: Details For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
