Date/Time: Fri, 22 Nov 2024 11:44:29 +0000
BTCUSDT-Perp-Binance Range/Renko Chart Problems With Numbers Bar Study
View Count: 81
[2024-10-10 02:19:07]
User660937 - Posts: 3
So BTCUSDT-Perp-Binance can generate time-based charts no problems, but when it comes to non-time-based charts with numbers bar Study added, it cannot generate no matter what the tick size is. BTCUSD-Perp-Binance can generate just fine with numbers bar, but USDT is having issues. Also, other coins on Binance that are USDT perp contracts work fine, it is just BTCUSDT that has issues. It gets stuck on loading whether I am using the intraday or historical. And yes, I have read the forum post about Crypto symbols with volume-based/numbers bar studies and none of the fixes work. I believe this to be an isolated issue with BTCUSDT-Perp-Binance. Please advise if possible, thank you!
[2024-10-10 14:35:21]
John - SC Support - Posts: 36203
Due to large volumes that are involved with the Crypto currencies, there is nothing further that can be done. Sierra Chart is simply not setup to deal with those particular items.
