Date/Time: Fri, 22 Nov 2024 06:09:45 +0000
Spreadsheet System for Trading, Cancel All Working Orders on Exit keeps resetting
View Count: 331
[2024-10-09 23:38:41]
User522425 - Posts: 13
When I change cell J70 from 0 to 1 in the attempt to enable "Cancel All Working Orders On Exit" so that when the Buy Exit or Sell Exit conditions are met, they will cancel my attached orders, then I run backtesting, the "Cancel All Working Orders On Exit" immediately resets to zero automatically, and I cannot see whether my attached orders are actually cancelled when Buy Exit or Sell Exit are triggered.
How to set Cancel All Working Orders On Exit to TRUE so that it doesn't automatically reset without user resetting the setting?
[2024-10-10 14:25:10]
John - SC Support - Posts: 36203
How are you setting the value for that cell? Are you using some kind of formula, or just entering a 0 or 1?
Also, what is the Spreadsheet System for Trading Input for "Use Column I and J Values Version 2" set to?
[2024-10-11 00:08:52]
For the first question, it is set to 1.
for the second question, it is Default spreadsheets System for trading study.scss, I think that's the question you are asking?
[2024-10-11 14:05:24]
On the Settings window for the "Spreadsheet System for Trading" there is an an Input towards the bottom called "Use Column I and J Values Version 2". We need to know what this is set to.
[2024-10-16 01:44:14]
So, I found it, thank you, so it is set to "No", what more can we provide you to further help troubleshoot this issue? I would love to be able to finish this phase soon. Again, thank for your help, you are awesome, and I appreciate your expertise.
Date Time Of Last Edit: 2024-10-16 01:49:37
[2024-10-17 02:53:07]
Sierra_Chart Engineering - Posts: 17143
You cannot set this directly on the Spreadsheet Sheet:
It is a read-only value there.
You need to set it through the Inputs:
Spreadsheet Systems, Alerts and Automated Trading: Spreadsheet Study Inputs that are Specific to Systems, Alerts, and Automated Trading
Spreadsheet Systems, Alerts and Automated Trading: Cancel All Working Orders On Exit
Date Time Of Last Edit: 2024-10-17 02:54:03
[2024-10-18 13:18:20]
The above question that was asked to us, above was asking if Column I and J Values Version 2 was set to, and my answer was it's set to "No", we need to know what further steps we need to take, and what setting(s) to change and to what and what to do next?
Date Time Of Last Edit: 2024-10-18 13:28:34
[2024-10-18 13:43:44]
The answer was given in post #6. That cell is read-only, so you can not set anything into it. It will always change to how the Inputs are set that control that item.
