Date/Time: Fri, 22 Nov 2024 10:56:21 +0000
change default sessios times for day session and evening session
View Count: 90
[2024-10-09 20:18:11]
User553413 - Posts: 60
I want to change the end of day session to 17:00:00 and beggining of evening session to 18:00:00 once without having to do that everytime I open a a new chart. Please help. I don't like having to do it evey time I open a chart. I want to change the default session times permanently so I don't have to worry about it every time instead of focusing on trading.
[2024-10-09 20:22:26]
John - SC Support - Posts: 36203
There is not a way to set this globally.
In order to do this you need to update the Symbol Settings for each instrument you will be opening a chart for. Keep in mind when you are editing the symbol settings for the Session Times, there is a Time Zone associated with this, that sets the time zone for the entered times in the symbol settings - this has no impact on the Time Zone of the chart. Refer to the following for how to edit symbol settings:
Global Symbol Settings: Instructions
