Date/Time: Wed, 27 Nov 2024 12:38:39 +0000
Command for setting all charts to symbol of active window
View Count: 970
[2014-09-05 10:48:22] |
User959258 - Posts: 3 |
I have just returned to sierra chart after some time away. I use a chartbook with several charts of the same symbol, each with a different time frame, displayed on one screen. I want to be able to easily change the symbol for all charts in the chartbook. As I recall, the command for this used to be ctrl+e but that doesn't seem to work now. Has this feature been eliminated or has the command changed? |
[2014-09-05 11:04:48] |
tobi - Posts: 351 |
you have to link your charts to the same symbol: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber then define the symbols you want to look at in the "Associated Watch List": https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#AssociatedSymbolList then you can easly "scroll through" these symbols using the keyboard buttons "+" or "-" |
[2014-09-06 05:28:17] |
The answer given in post #2 is correct.
