Date/Time: Fri, 22 Nov 2024 11:13:25 +0000
difference indicator
View Count: 81
[2024-10-09 19:17:42] |
Boris Libman - Posts: 58 |
looking to add a study that calculates a spread (either difference or ratio) between price and value of another study in the chart that always has a non-zero value. "Difference" doesn't seem to accomplish this because I cannot reference the value of the other study to compare to price.
[2024-10-09 19:21:16] |
John - SC Support - Posts: 36203 |
There are two different studies - "Study Subgraph Subtract" and "Study Subgraphs Subtract/Difference". Note the plural 'Subgraphs' in the second one. That is the one you should be using. If that is what you are using, then we do not understand what you mean by "I cannot reference the value of the other study to compare to price." For this study, if you are comparing to the current price, then you would use the Main Price Graph - Last to get the current price. And you can then reference the other study you want. Refer to the following: Study Subgraphs Subtract/Difference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
