Date/Time: Fri, 22 Nov 2024 11:02:09 +0000
Possible bug on spreadsheet plotting with position on/off
View Count: 87
[2024-10-09 15:37:03] |
User484096 - Posts: 13 |
I use a spreadsheet for plotting and have 2 set of plots, one without position, one with position. Whenever the position change from on to off or off to on, only the left most 10 or so bars got updated. It will clear up after when one or two new bars is generated. In the screenshot, I have multiple ATRs plotted when position is on. When off, 3 bars high low. I'm on version 2671 but I noticed this in previous version as well. |
sc plot.png / V - Attached On 2024-10-09 15:36:38 UTC - Size: 18.62 KB - 21 views |
[2024-10-09 17:46:27] |
John - SC Support - Posts: 36203 |
We are not exactly sure what you are doing, but what you are seeing with the 10 bars updating is correct for the Spreadsheet studies. Those studies only update the most recent 10 rows in order to not recalculate everything every time. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Spreadsheet Calculations and Spreadsheet Study Processing of Spreadsheet Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-09 22:22:37] |
Sawtooth - Posts: 4118 |
You could force a recalculation with the Chart Recalculation - Periodic study.
