Date/Time: Fri, 22 Nov 2024 09:52:50 +0000
Trading XBTUSD, BTCUSD PERP
View Count: 117
[2024-10-08 19:42:37] |
User769783 - Posts: 182 |
Is it possible to trade these two markets with a reliable SC supported broker, the XBTUSD or the BTCUSD PERP? Having a hard time finding a broker that even offers these as tradeable contracts. Thanks
[2024-10-08 21:18:36] |
John - SC Support - Posts: 36203 |
The only broker that we work with that might offer the ability to trade Bitcoin is Interactive Brokers. You would have to check with them if they are offering this - we thought they had recently added this. Refer to the following regarding using Interactive Brokers with Sierra Chart: Interactive Brokers Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-08 21:25:13] |
But specifically, these two markets?
[2024-10-08 21:41:29] |
Those two symbols are the Bitcoin to USD ratio, the same as a FOREX pair. Each broker is going to use a different nomenclature for what they call this. You need to talk to the broker to see what they have and what they call it.
[2024-10-08 22:07:48] |
Would this be the BRR, are you familiar? This is what they offer but I cant tell if its the same as the xbtusd
[2024-10-09 14:00:13] |
We do not know. You need to ask them about this.
