Date/Time: Mon, 25 Nov 2024 14:09:14 +0000
DPL showing incorrectly
View Count: 82
[2024-10-08 16:54:44] |
Boris Libman - Posts: 58 |
Pretty sure I've asked this before but cannot find it in my prior messages. I trade using IB and a couple of days ago had an overnight position that was executed on IB outside of SC. While SC trade window has picked up the position correctly, the DPL has been wrong for two days now. How do I either reset it or match up the buys/sells so that it's reflected correctly?
[2024-10-08 19:33:01] |
Refer to the following: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-08 20:01:57] |
your answer doesn't address DPL showing up incorrectly, can you please address.
[2024-10-08 21:19:22] |
Refer to the following, but the basic information is the same: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
