Date/Time: Fri, 22 Nov 2024 10:35:56 +0000
Can I get some help to draw an extending rectangle of 10 points?
View Count: 87
[2024-10-08 16:28:54]
pennydoll9 - Posts: 20
I would like to plot an extending rectangle by default of 10 points, Is that Possible? Can I get some help? Thanks!
[2024-10-08 19:14:03]
John - SC Support - Posts: 36203
There is no built-in method to default a rectangle (extending or otherwise) to a specific height (i.e. 10 points). The only way to do this would be to create a Custom Study that draws the rectangle for you with that height. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
