Date/Time: Fri, 22 Nov 2024 10:26:13 +0000
chart DOM - is it possible to save column layout
View Count: 81
[2024-10-08 15:57:20]
MarketBeast - Posts: 26
Thank you.
I have one more question. for chart DOM is it possible to save column layout as default so for new charts I don't have to insert the columns again.
[2024-10-08 16:25:40]
John - SC Support - Posts: 36203
The only way to do this is to set the DOM the way you want it and then use that chart as a template. Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
