Date/Time: Fri, 22 Nov 2024 11:11:36 +0000
Delayed Data Denali
View Count: 100
[2024-10-08 13:48:46] |
cesium - Posts: 85 |
Hello Support, trying to problem solve why Denali data is delayed for me I looked in my control panel and everything looks ok Thank you Date Time Of Last Edit: 2024-10-08 14:03:34
[2024-10-08 14:50:50] |
John - SC Support - Posts: 36203 |
The exchange that you had active did not renew on October 1, 2024 due to insufficient funds in your account at that time. You can re-activate the exchange, or select different exchange options for the CME Group, at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
