Date/Time: Fri, 22 Nov 2024 10:46:29 +0000
Chart drawing configs
View Count: 197
[2024-10-08 13:48:26] |
nosast - Posts: 312 |
Updated SC to the current prerelease and my chart drawing config shortcuts seem not to be working anymore. Configs are now accessible in a submenu "Configuration". Did anything change here so I need to adjust my settings? Please see attached screenshot. Date Time Of Last Edit: 2024-10-08 15:53:47
SNAG_ 2024-10-08 - 08-20-19.png / V - Attached On 2024-10-08 13:48:40 UTC - Size: 16.88 KB - 45 views |
[2024-10-08 22:39:15] |
Sierra_Chart Engineering - Posts: 17143 |
Update Sierra Chart to the current version to resolve this. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-09 16:07:46] |
Thanks! 2690 fixed it.
