Date/Time: Fri, 22 Nov 2024 10:54:40 +0000
RVOL
View Count: 83
[2024-10-08 10:30:46] |
User862138 - Posts: 19 |
Good day, I see many other platforms refer to RVOL as between +3 and -3 as elevated. Why do I see RVol as i.e 60 and even more? Is there are specific setting for this? Best |
[2024-10-08 14:35:53] |
John - SC Support - Posts: 36203 |
We can not speak to how other systems display certain information. If you are referring to the Relative Volume study, then a value of 60 is 60%, meaning that the relative volume is 60% of the average volume for that time, so it is lower than the average. A value of 100% would mean it is exactly the same and a value over 100 means it is higher than the average. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
