Date/Time: Tue, 22 Apr 2025 22:48:37 +0000
Last Daily Bar does not print.
View Count: 258
[2024-10-08 00:49:25] |
3152sier - Posts: 52 |
Hello Support 1. Today's daily bar prints during live trading but not after the trading session. This happens if I close and re-open Sierra application. I can see the daily bar if I don't close the application. 2. The same thing happens with Daily Change Price. After closing and re-opening the application, Daily Change Price shows 0.00. Note: I am not connected to the broker when I re-open Sierra. Please help, thanks. |
[2024-10-08 22:09:52] |
Sierra_Chart Engineering - Posts: 19305 |
We have no idea what symbol you are referring to. Just tell us one particular symbol. One symbol only. We need the exact complete symbol.
[2024-10-11 03:31:13] |
Sorry symbol was QQQ. Thanks. |
[2024-10-17 02:00:10] |
Update Sierra Chart to the latest version: Software Download: Fast Update In the Global Settings >> Data/Trade Service Settings >> Common Settings window: Data/Trade Service Settings: Common Settings Set this setting as follows: Historical Daily Equities Data Download Time: 20:15:00 And make sure the corresponding time zone is US Eastern Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-17 02:00:36
[2024-12-24 01:03:18] |
Hello Support: I have the same problem again i.e. last (today's) daily bar not printing unless connected to data service. Symbols QQQ, TSLA nvda and others. my current settings are: Historical Daily Equities Data Download Time: 20:15:00 ET Sierra version 2719. Please help. Thanks |
[2024-12-26 07:52:27] |
We see the data. Use this command from the Edit menu while the charts are open: Edit Menu: Edit >> Download Data For All Historical Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
