Date/Time: Wed, 27 Nov 2024 12:32:22 +0000
numbers bar spacing
View Count: 1691
[2014-09-05 05:41:59] |
User38813 - Posts: 20 |
[img]http://imagizer.imageshack.com/img540/7973/VwZfKV.png[/img] As per above chart i am not able to adjust its size. If i tries to adjust it up to readable image then only single bar of current time appers , no older time frame bar appears. e.g if ichoose 5 min bar then at any time only one or 2 bars apperas on my screen . Older bar say of last one hours(ie last 12 bars) didnot appears. If i tries to adjust it again then bar appears but charts are not readble its jumbled up..... Pls help me out images attached [img]http://imagizer.imageshack.com/img746/1632/BdmWEe.png[/img] in above image bar are crosses above and below axis |
[2014-09-05 05:59:10] |
One thing which will help is to change Chart >> Chart Settings >> Tick Size to .1.
[2014-09-05 06:01:37] |
We have contacted Global Data Feeds to get access to this particular symbol so we can test it.
[2014-09-07 05:03:46] |
Sir i have adjusted chart setting as suggested by you . Followings are the screen shot of chart setting . Please advice me to clear the view further. 1. http://imagizer.imageshack.com/img674/2483/mNHgTE.png 2 http://imagizer.imageshack.com/img661/4835/zo8qPt.png In second screenshot i am doubtful about scale increment and horizontal grid line increment . Please look it into and suggest if any changes required here . because with all this setting still my chart is not clear it goes beyond vertical length of charts. Single bar is not visible as it crosses beyond charts heights .( screen shot attached). Also as per my last post, still i am not able to view full charts http://imagizer.imageshack.com/img901/6379/cKGVoW.png]Screenshot Date Time Of Last Edit: 2014-09-09 06:08:49
[2014-09-07 05:15:56] |
screen shot link 1 [img]http://imagizer.imageshack.com/img537/7614/u9Cg8n.png[/img] 2 [img]http://imagizer.imageshack.com/img673/3858/kom9Iw.png[/img] 3 [img]http://imagizer.imageshack.com/img674/7299/kv3AKE.png[/img] |
[2014-09-08 20:42:07] |
We are going to be reviewing this today. One thing we noticed is you did not change the Tick Size. You only changed the Price Display Format. Set the Tick Size in Chart >> Chart Settings to .1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-09 06:10:19
[2014-09-09 03:03:02] |
thanks
Date Time Of Last Edit: 2014-09-09 04:26:05
[2014-09-09 06:12:37] |
We have reviewed this now. See the attachments and look at the settings we have and also the final chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-09 06:12:47
2014-09-09_173443.png / V - Attached On 2014-09-09 06:11:42 UTC - Size: 16.39 KB - 433 views SBIN-NS-FUT-201409 10 Min #1 2014-09-09 02_11_00.804.png / V - Attached On 2014-09-09 06:12:25 UTC - Size: 47.14 KB - 465 views |
