Date/Time: Fri, 22 Nov 2024 11:23:12 +0000
yearly VWAP
View Count: 88
[2024-10-07 22:11:25] |
User939307 - Posts: 1 |
Hi: I'm trading in sim account and I have yearly VWAP with volume bars , The problem is it's not updated from historical time tile now at same time all others charts are working like (quarterly ,monthly ,weakly )VWAP . So ,what can I do ? Thanks a lot. |
[2024-10-08 15:32:22] |
John - SC Support - Posts: 36203 |
If you are missing data, then follow these instructions to redownload the missing data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If you are not getting any data for a specific chart, then what is the exact symbol for that chart as it is entered on "Chart >> Chart Settings >> Symbol >> Symbol"? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
