Date/Time: Fri, 22 Nov 2024 11:32:52 +0000
Can Sierra Chart support Multi-Prop and copytrading?
View Count: 132
[2024-10-07 17:37:37]
skyfly93 - Posts: 34
Can Sierra Chart support users who have multiple different sim-funded accounts at different companies, but all under Rithmic?
Is it possible to set copy trading so that all accounts can get copied and traded?
Currently, a user has to update the trade/data connection each time to access a different company account, and then undo and redo all of the copy trade settings per different sim-funded account per instrument. This is too much of an administrative burden.
[2024-10-07 17:45:41]
John - SC Support - Posts: 36203
Yes.
No. Our "Order Allocation to Trade Accounts" only works with accounts that are under a single login. Refer to the information here:
It is best to use a separate installation of Sierra Chart for each trading service you are connecting to. This includes different Rithmic accounts. This way, you are not changing the "Data/Trade Service Settings" for each connection, you just change to a different Sierra Chart running for that particular connection. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Note that if you are using our Denali Exchange Data Feed, then you can only get the data to a total of 3 concurrent instances on a single computer. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed Connections on Same Computer Simultaneously
