Date/Time: Wed, 27 Nov 2024 12:29:44 +0000
"Save" choice on files menu
View Count: 938
[2014-09-05 05:01:22] |
Willson - Posts: 176 |
On File menu, What does Ctrl-S, (save) actually save? I thought it saved the currently active chartBook. But not so. How can I save current chartbook without closing it? Regards |
[2014-09-05 07:05:37] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html The save command most definitely does work as documented. We have verified that now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
