Date/Time: Mon, 25 Nov 2024 16:16:19 +0000
Cannot open own data text file.
View Count: 73
[2024-10-07 15:29:30] |
User198125 - Posts: 38 |
Hello, I have created a txt file that I wish to upload in to Sierra Chart and open as a new/historical chart. I have followed all the instructions as per below page: Text/CSV Data Format: Supported Data Line Formats I have installed a separate SC. I have set the data Global Settings >> Data/Trade Service Settings >> "No Service". When I try and load the file, I keep getting message, "Symbol settings no found for current service". I am attaching a copy of the message log file and the text file Please can you help. Thank you. Date Time Of Last Edit: 2024-10-07 15:30:01
ZT_price.txt - Attached On 2024-10-07 15:28:41 UTC - Size: 1.31 KB - 40 views MessageLog_txt_file.txt - Attached On 2024-10-07 15:29:58 UTC - Size: 6.72 KB - 40 views |
[2024-10-07 16:33:20] |
John - SC Support - Posts: 36248 |
You have a bunch of extra lines at the end of the file. Remove these and have just a single extra line at the end (i.e. make sure you select Enter at the end of the last data entry so there is just that last single line).
