Date/Time: Mon, 25 Nov 2024 16:02:39 +0000
Discrepancy Between Current Prices and Executions
View Count: 112
[2024-10-07 14:37:52]
voy - Posts: 14
I am encountering an issue with my Range Execution Chart while using the M6E Dec 2024 MICRO EUR/USD. The current price displayed on the chart is significantly different from the execution prices, which are clustered around a different level. The current price displayed is at a much higher level than where the executions are taking place (please see the attached screenshot). The discrepancy appears both in the simulated environment and when using real-time data. I have double-checked the symbol and data feed to ensure they are correct for this contract.
Could you please assist me in identifying the cause of this discrepancy and suggest a solution? I’ve attached a screenshot for your reference.
Thank you for your help.
https://www.sierrachart.com/image.php?Image=1728311795734.png
[2024-10-07 16:11:54]
John - SC Support - Posts: 36248
Are you using a "Trade And Current Quote Symbol" for this chart? If so, what is this set to? Refer to the following:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
