Date/Time: Fri, 22 Nov 2024 16:42:10 +0000
American stocks
View Count: 63
[2024-10-07 12:37:31] |
Deltareversal - Posts: 45 |
Is it possible to view American company stocks with delayed data? Denali or with which data provider?
[2024-10-07 13:44:59] |
Sierra_Chart Engineering - Posts: 17143 |
Yes this is supported. Refer to: US Stock/Equities Consolidated Tape Data Feed You will need to use the Delayed Exchange Data Feed which is included. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
