Date/Time: Fri, 22 Nov 2024 11:39:05 +0000
Delta % - Ask Volume Bid Volume
View Count: 87
[2024-10-07 11:17:40] |
User650826 - Posts: 9 |
Hi, I'd like to incorporate the Delta % - Ask Volume Bid Volume Difference Percent subgraph to the grid and I was wondering if there was a way to round the numbers displayed to the nearest whole number. For example if the delta is 19.90% of the total volume, then display 20%. This would make for much faster analysis.Can't find a setting in study to remove or round up the Decimal. Thanks |
[2024-10-07 15:23:48] |
John - SC Support - Posts: 36203 |
There is a way to do this, but it is not a direct setting for what you are looking for. Also, it will affect all the information in the Numbers Bars Calculated Values, but you could setup a Numbers Bars Calculated Values just for this one item. What you can do is set the Input for "Use Default Number Formatting for All Subgraphs". This will then display the percentages as the whole number only. Refer to the information for this Input in the following section: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
