Date/Time: Fri, 22 Nov 2024 11:45:07 +0000
Study only show when above below moving average
View Count: 119
[2024-10-07 09:51:27] |
User436410 - Posts: 4 |
Hi Just for the sake of visual clarity is there a way to only show my study when its above or below a moving average. Tried a few ways.. but nope. Thanks & appreciate any help |
[2024-10-07 13:41:54] |
Sierra_Chart Engineering - Posts: 17143 |
Have a look at using this study: Color Bar Based on Alert Condition You would need to set this Input: Color Bar Based on Alert Condition: Output When Condition Is True To Use Input Data and also base the Color Bar study on the original study. You would also need to use a Subgraph style, that is not a continuous line. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-07 13:44:26
[2024-10-08 10:22:42] |
Hi Thanks, I don;t understand this, any chance of an example?? thx
[2024-10-08 14:26:29] |
John - SC Support - Posts: 36203 |
Item #57 at the following link gives an example of how to do this: Additional Files (Study Collections, Spreadsheets, Chartbooks) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
