Date/Time: Fri, 22 Nov 2024 11:45:20 +0000
Transferring Menu bar buttons from one computer to another
View Count: 77
[2024-10-06 20:27:26] |
User409644 - Posts: 45 |
hi. is there a way to transfer my saved menu buttons at the top of a chart to a new computer? I have saved 25 buttons or so, and woould love to be able to send a file to my new computer so I dont need to redo the entire set of buttons. Thank you. Ira |
[2024-10-07 15:02:46] |
John - SC Support - Posts: 36203 |
Refer to Step #5 at the following link for what files contain certain information so you can copy the appropriate file: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
