Date/Time: Fri, 22 Nov 2024 11:47:11 +0000
Chart Shortcut Menu
View Count: 105
[2024-10-06 17:09:37]
TheBish75 - Posts: 13
After upgrading Sierra Chart to the latest version I had to install a previous version due to the Numbers Bar study being broken. When I reverted the right click chart shortcut menu appears with the separators but my menu items are not there.
attachmentchart shortcut menu broken.mp4 - Attached On 2024-10-06 17:09:14 UTC - Size: 507.51 KB - 58 views
[2024-10-07 14:53:24]
John - SC Support - Posts: 36203
There was a problem with the Right Click Shortcut menus in a few releases. We recommend updating to the current release.
There was a change to the Numbers Bars study to allow for better control of how comparisons with zero or NULL values are handled. There are two new Inputs on the Numbers Bars study to control these. Refer to the following and the item below it:
Numbers Bars: Enable Diagonal Bid/Ask Compare with No Data at High/Low
