Date/Time: Fri, 22 Nov 2024 11:46:12 +0000
Chartbook Keyboard Shortcuts
View Count: 123
[2024-10-06 14:10:35]
Straddle1428 - Posts: 29
Hi, i found the Chartbook Keyboard Shortcuts where i can set a shortcut for chartbook 1..x
but nothing hsappens when pressing the short cut...? is there any other setting i have to make in order for it to work? or do i understand it wrong and it cant directly switch to, say, chartbook 3?
thanks
[2024-10-07 14:49:42]
John - SC Support - Posts: 36203
You need to first assign the chartbook items to a specific chartbook. You do this through the Control Bar button setup by adding the Control Bar Button option for the Chartbook, selecting it on the right and then selecting the "Customize" button. A new window comes up that allows you to select the Chartbook to assign to that Control Bar button.
Once you have the Control Bar buttons assigned to a specific chartbook, then the Keyboard Shortcuts will work for those assigned chartbooks.
Note that once you setup the Control Bar button, it does not need to be part of any actual control bar. You just use the Control Bar button setup to assign the specific chartbook.
Refer to the information at the following link for Trade Window configurations. The above follows this same principle.
Control Bar: Control Bar Trade Window Configuration Buttons
Date Time Of Last Edit: 2024-10-07 14:49:52
