Date/Time: Fri, 22 Nov 2024 11:50:18 +0000
Bug.: Calculator tool does not show text, if its colour is yellow.png
View Count: 93
[2024-10-05 18:07:54] |
User408639 - Posts: 66 |
Moin Moin. This is a weird one, but not important.: The ALT-2 Calculator tool does not show text, if its colour is yellow. The attached Screenshot does show texted lines for measurements (in this case arbitrary ones just for the show), ,which are being.: 1. labelled for the red ones. 2. Bit I am changing its colour to yellow, I do just get the lines. _Tschüß, __Michael. |
Calculator tool does not show text, if its colour is yellow.png / V - Attached On 2024-10-05 18:07:27 UTC - Size: 195.95 KB - 30 views Attachment Deleted. |
[2024-10-07 14:06:09] |
John - SC Support - Posts: 36203 |
Please get us a chart that shows this issue and we will see if we can reproduce it. Follow these instructions to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
