Date/Time: Wed, 27 Nov 2024 12:27:11 +0000
Cannot Connect
View Count: 931
[2014-09-04 22:52:48]
dennismed - Posts: 62
Software version: 1187 | 2014-09-04 18:50:41
Usage end date: 2014-10-15 | 2014-09-04 18:50:41
Enabled for: Advanced Features. | 2014-09-04 18:50:41
Enabled for: Advanced Features 2. | 2014-09-04 18:50:41
Enabled for: Sierra Chart Historical Data Service. | 2014-09-04 18:50:41
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-09-04 18:50:41
Active service: Open E Cry FIX | 2014-09-04 18:50:41
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-09-04 18:50:41
2014-09-04 17:50:41 Local computer clock time | 2014-09-04 18:50:41
2014-09-04 22:50:41 GMT time | 2014-09-04 18:50:41
2014-09-04 18:50:41 Time zone adjusted time | 2014-09-04 18:50:41
Time difference to server time: 4 seconds. | 2014-09-04 18:50:41
Program path: C:\SierraChart\ | 2014-09-04 18:50:41
Data Files path: C:\SierraChart\Data\ | 2014-09-04 18:50:41
OS Version Number: 6.1 | 2014-09-04 18:50:41
Checking for new symbol settings for oec | 2014-09-04 18:50:41
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-09-04 18:50:41
HTTP connection to www.sierrachart.com:80 (1232) | Connected. | 2014-09-04 18:50:41
Symbol settings are up-to-date for oec | 2014-09-04 18:50:42
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:50:46
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:50:46
OEC FIX Trading socket (1752) | Connected. | 2014-09-04 18:50:46
OEC FIX Trading socket (1752) | Starting SSL connection. | 2014-09-04 18:50:46
OEC FIX Trading socket (1752) | SSL connection established. | 2014-09-04 18:50:47
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:50:48
OEC FIX Trading socket (1752) | Closed. No error. | 2014-09-04 18:50:48
OEC FIX Trading socket (1752) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:50:48
OEC FIX Trading socket (1752) | SSL has been shut down. | 2014-09-04 18:50:48
OEC FIX Trading socket (1752) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:50:48
OEC FIX Trading socket (1752) | Shutdown and closed. | 2014-09-04 18:50:48
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:50:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:50:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:50:48
Disconnected from Open E Cry. | 2014-09-04 18:50:48
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:50:48
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:50:51
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:50:51
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:50:51
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:50:51
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:50:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:50:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:50:51
Disconnected from Open E Cry. | 2014-09-04 18:50:51
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:50:51
HTTP connection to www.sierrachart.com:80 (1232) | Closed. No error. | 2014-09-04 18:50:52
HTTP connection to www.sierrachart.com:80 (1232) | Shutdown and closed. | 2014-09-04 18:50:52
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:50:54
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:50:54
OEC FIX Trading socket (1240) | Connected. | 2014-09-04 18:50:54
OEC FIX Trading socket (1240) | Starting SSL connection. | 2014-09-04 18:50:54
OEC FIX Trading socket (1240) | SSL connection established. | 2014-09-04 18:50:54
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:50:55
OEC FIX Trading socket (1240) | Closed. No error. | 2014-09-04 18:50:55
OEC FIX Trading socket (1240) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:50:55
OEC FIX Trading socket (1240) | SSL has been shut down. | 2014-09-04 18:50:55
OEC FIX Trading socket (1240) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:50:55
OEC FIX Trading socket (1240) | Shutdown and closed. | 2014-09-04 18:50:55
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:50:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:50:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:50:55
Disconnected from Open E Cry. | 2014-09-04 18:50:55
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:50:55
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:50:58
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | Connected. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | Starting SSL connection. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | SSL connection established. | 2014-09-04 18:50:58
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | Closed. No error. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | SSL has been shut down. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:50:58
OEC FIX Trading socket (1232) | Shutdown and closed. | 2014-09-04 18:50:58
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:50:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:50:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:50:58
Disconnected from Open E Cry. | 2014-09-04 18:50:58
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:50:58
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:01
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | Connected. | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | Starting SSL connection. | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | SSL connection established. | 2014-09-04 18:51:01
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | Closed. No error. | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | SSL has been shut down. | 2014-09-04 18:51:01
OEC FIX Trading socket (1240) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:02
OEC FIX Trading socket (1240) | Shutdown and closed. | 2014-09-04 18:51:02
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:02
Disconnected from Open E Cry. | 2014-09-04 18:51:02
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:02
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:05
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | Connected. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | Starting SSL connection. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | SSL connection established. | 2014-09-04 18:51:05
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | Closed. No error. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | SSL has been shut down. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:05
OEC FIX Trading socket (1232) | Shutdown and closed. | 2014-09-04 18:51:05
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:05
Disconnected from Open E Cry. | 2014-09-04 18:51:05
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:05
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:08
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | Connected. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | Starting SSL connection. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | SSL connection established. | 2014-09-04 18:51:08
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | Closed. No error. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | SSL has been shut down. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:08
OEC FIX Trading socket (1240) | Shutdown and closed. | 2014-09-04 18:51:08
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:08
Disconnected from Open E Cry. | 2014-09-04 18:51:08
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:08
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:11
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:11
OEC FIX Trading socket (1232) | Connected. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | Starting SSL connection. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | SSL connection established. | 2014-09-04 18:51:12
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | Closed. No error. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | SSL has been shut down. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:12
OEC FIX Trading socket (1232) | Shutdown and closed. | 2014-09-04 18:51:12
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:12
Disconnected from Open E Cry. | 2014-09-04 18:51:12
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:12
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:15
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | Connected. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | Starting SSL connection. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | SSL connection established. | 2014-09-04 18:51:15
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | Closed. No error. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | SSL has been shut down. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:15
OEC FIX Trading socket (1752) | Shutdown and closed. | 2014-09-04 18:51:15
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:15
Disconnected from Open E Cry. | 2014-09-04 18:51:15
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:15
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:18
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:18
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:51:18
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:51:18
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:51:19
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:19
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:51:19
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:19
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:51:19
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:19
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:51:19
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:19
Disconnected from Open E Cry. | 2014-09-04 18:51:19
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:19
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:22
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | Connected. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | Starting SSL connection. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | SSL connection established. | 2014-09-04 18:51:22
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | Closed. No error. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | SSL has been shut down. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:22
OEC FIX Trading socket (1752) | Shutdown and closed. | 2014-09-04 18:51:22
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:22
Disconnected from Open E Cry. | 2014-09-04 18:51:22
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:22
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:25
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:25
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:51:28
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:51:28
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:51:29
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:29
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:51:29
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:29
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:51:29
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:29
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:51:29
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:29
Disconnected from Open E Cry. | 2014-09-04 18:51:29
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:29
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:32
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:32
OEC FIX Trading socket (1752) | Connected. | 2014-09-04 18:51:32
OEC FIX Trading socket (1752) | Starting SSL connection. | 2014-09-04 18:51:32
OEC FIX Trading socket (1752) | SSL connection established. | 2014-09-04 18:51:32
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:33
OEC FIX Trading socket (1752) | Closed. No error. | 2014-09-04 18:51:33
OEC FIX Trading socket (1752) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:33
OEC FIX Trading socket (1752) | SSL has been shut down. | 2014-09-04 18:51:33
OEC FIX Trading socket (1752) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:33
OEC FIX Trading socket (1752) | Shutdown and closed. | 2014-09-04 18:51:33
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:33
Disconnected from Open E Cry. | 2014-09-04 18:51:33
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:33
Current selected Data/Trading service: Open E Cry FIX | 2014-09-04 18:51:35
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:36
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | Connected. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | Starting SSL connection. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | SSL connection established. | 2014-09-04 18:51:36
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | Closed. No error. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | SSL has been shut down. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:36
OEC FIX Trading socket (1752) | Shutdown and closed. | 2014-09-04 18:51:36
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:36
Disconnected from Open E Cry. | 2014-09-04 18:51:36
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:36
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:39
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:39
OEC FIX Trading socket (488) | Connected. | 2014-09-04 18:51:39
OEC FIX Trading socket (488) | Starting SSL connection. | 2014-09-04 18:51:39
OEC FIX Trading socket (488) | SSL connection established. | 2014-09-04 18:51:39
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:40
OEC FIX Trading socket (488) | Closed. No error. | 2014-09-04 18:51:40
OEC FIX Trading socket (488) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:40
OEC FIX Trading socket (488) | SSL has been shut down. | 2014-09-04 18:51:40
OEC FIX Trading socket (488) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:40
OEC FIX Trading socket (488) | Shutdown and closed. | 2014-09-04 18:51:40
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:40
Disconnected from Open E Cry. | 2014-09-04 18:51:40
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:40
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:43
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | Connected. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | Starting SSL connection. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | SSL connection established. | 2014-09-04 18:51:43
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | Closed. No error. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | SSL has been shut down. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:43
OEC FIX Trading socket (688) | Shutdown and closed. | 2014-09-04 18:51:43
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:43
Disconnected from Open E Cry. | 2014-09-04 18:51:43
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:43
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:46
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:46
OEC FIX Trading socket (488) | Connected. | 2014-09-04 18:51:46
OEC FIX Trading socket (488) | Starting SSL connection. | 2014-09-04 18:51:46
OEC FIX Trading socket (488) | SSL connection established. | 2014-09-04 18:51:46
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:46
OEC FIX Trading socket (488) | Closed. No error. | 2014-09-04 18:51:46
OEC FIX Trading socket (488) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:46
OEC FIX Trading socket (488) | SSL has been shut down. | 2014-09-04 18:51:47
OEC FIX Trading socket (488) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:47
OEC FIX Trading socket (488) | Shutdown and closed. | 2014-09-04 18:51:47
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:47
Disconnected from Open E Cry. | 2014-09-04 18:51:47
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:47
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:50
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | Connected. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | Starting SSL connection. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | SSL connection established. | 2014-09-04 18:51:50
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | Closed. No error. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | SSL has been shut down. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:50
OEC FIX Trading socket (688) | Shutdown and closed. | 2014-09-04 18:51:50
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:50
Disconnected from Open E Cry. | 2014-09-04 18:51:50
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:50
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:53
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | Connected. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | Starting SSL connection. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | SSL connection established. | 2014-09-04 18:51:53
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | Closed. No error. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | SSL has been shut down. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:53
OEC FIX Trading socket (488) | Shutdown and closed. | 2014-09-04 18:51:53
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:53
Disconnected from Open E Cry. | 2014-09-04 18:51:53
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:53
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:51:56
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:51:56
OEC FIX Trading socket (688) | Connected. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | Starting SSL connection. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | SSL connection established. | 2014-09-04 18:51:57
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | Closed. No error. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | SSL has been shut down. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:51:57
OEC FIX Trading socket (688) | Shutdown and closed. | 2014-09-04 18:51:57
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:51:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:51:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:51:57
Disconnected from Open E Cry. | 2014-09-04 18:51:57
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:51:57
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:00
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | Connected. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | Starting SSL connection. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | SSL connection established. | 2014-09-04 18:52:00
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | Closed. No error. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | SSL has been shut down. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:00
OEC FIX Trading socket (488) | Shutdown and closed. | 2014-09-04 18:52:00
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:00
Disconnected from Open E Cry. | 2014-09-04 18:52:00
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:00
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:03
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:03
OEC FIX Trading socket (688) | Connected. | 2014-09-04 18:52:03
OEC FIX Trading socket (688) | Starting SSL connection. | 2014-09-04 18:52:03
OEC FIX Trading socket (688) | SSL connection established. | 2014-09-04 18:52:04
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:04
OEC FIX Trading socket (688) | Closed. No error. | 2014-09-04 18:52:04
OEC FIX Trading socket (688) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:04
OEC FIX Trading socket (688) | SSL has been shut down. | 2014-09-04 18:52:04
OEC FIX Trading socket (688) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:04
OEC FIX Trading socket (688) | Shutdown and closed. | 2014-09-04 18:52:04
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:04
Disconnected from Open E Cry. | 2014-09-04 18:52:04
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:04
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:07
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | Connected. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | Starting SSL connection. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | SSL connection established. | 2014-09-04 18:52:07
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | Closed. No error. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | SSL has been shut down. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:07
OEC FIX Trading socket (1752) | Shutdown and closed. | 2014-09-04 18:52:07
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:07
Disconnected from Open E Cry. | 2014-09-04 18:52:07
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:07
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:10
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:10
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:52:10
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:52:10
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:52:11
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:11
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:52:11
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:11
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:52:11
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:11
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:52:11
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:11
Disconnected from Open E Cry. | 2014-09-04 18:52:11
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:11
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:14
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | Connected. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | Starting SSL connection. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | SSL connection established. | 2014-09-04 18:52:14
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | Closed. No error. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | SSL has been shut down. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:14
OEC FIX Trading socket (1772) | Shutdown and closed. | 2014-09-04 18:52:14
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:14
Disconnected from Open E Cry. | 2014-09-04 18:52:14
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:14
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:17
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:17
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:52:17
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:52:17
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:52:17
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:18
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:52:18
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:18
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:52:18
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:18
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:52:18
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:18
Disconnected from Open E Cry. | 2014-09-04 18:52:18
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:18
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:21
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | Connected. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | Starting SSL connection. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | SSL connection established. | 2014-09-04 18:52:21
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | Closed. No error. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | SSL has been shut down. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:21
OEC FIX Trading socket (1772) | Shutdown and closed. | 2014-09-04 18:52:21
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:21
Disconnected from Open E Cry. | 2014-09-04 18:52:21
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:21
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:24
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:24
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:52:24
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:52:24
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:52:24
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:25
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:52:25
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:25
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:52:25
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:25
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:52:25
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:25
Disconnected from Open E Cry. | 2014-09-04 18:52:25
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:25
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:28
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | Connected. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | Starting SSL connection. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | SSL connection established. | 2014-09-04 18:52:28
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | Closed. No error. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | SSL has been shut down. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:28
OEC FIX Trading socket (1772) | Shutdown and closed. | 2014-09-04 18:52:28
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:28
Disconnected from Open E Cry. | 2014-09-04 18:52:28
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:28
Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-09-04 18:52:31
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-09-04 18:52:31
OEC FIX Trading socket (1748) | Connected. | 2014-09-04 18:52:31
OEC FIX Trading socket (1748) | Starting SSL connection. | 2014-09-04 18:52:31
OEC FIX Trading socket (1748) | SSL connection established. | 2014-09-04 18:52:31
OEC FIX Trading: Sending the Logon message. | 2014-09-04 18:52:32
OEC FIX Trading socket (1748) | Closed. No error. | 2014-09-04 18:52:32
OEC FIX Trading socket (1748) | SSL shutdown indicates not able to send 'close notify'. | 2014-09-04 18:52:32
OEC FIX Trading socket (1748) | SSL has been shut down. | 2014-09-04 18:52:32
OEC FIX Trading socket (1748) | SSL object has been freed. SSL state is now disconnected. | 2014-09-04 18:52:32
OEC FIX Trading socket (1748) | Shutdown and closed. | 2014-09-04 18:52:32
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-09-04 18:52:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-04 18:52:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-04 18:52:32
Disconnected from Open E Cry. | 2014-09-04 18:52:32
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-09-04 18:52:32
[2014-09-05 00:32:42]
These are the relevant messages:
Refer to the documentation here about this:
http://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem
Date Time Of Last Edit: 2014-09-05 00:32:55
