Date/Time: Fri, 22 Nov 2024 11:33:29 +0000
unable to open HSI chart - weird error
View Count: 98
[2024-10-05 15:39:38]
Straddle1428 - Posts: 29
when trying to open an HSI-202411-HKFE daily chart, i get the attached error message
Download Failed
Error Downloading historical Daily
data for HSI-202411-HKFE. Error
user is not authorized to execute
query for one or more of the specified
symbols
i have market data subscribed and minute data works just fine.
please advice
image2024-10-05_19-34.png / V - Attached On 2024-10-05 15:35:49 UTC - Size: 126.91 KB - 22 views
[2024-10-05 16:37:05]
Sierra_Chart Engineering - Posts: 17143
This is now resolved.
Re-download the data:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
[2024-10-05 16:58:06]
thank you for working on it that quickly
unfortunately it does not download properly.. i get data until end of 2022 and then there is a gap way into 2023.
when trying to download the missing data i get the error attached
image2024-10-05_20-56.png / V - Attached On 2024-10-05 16:58:00 UTC - Size: 84.97 KB - 25 views
[2024-10-07 14:47:48]
This is an Interactive Brokers error. You need to contact Interactive Brokers for help.
