Date/Time: Fri, 22 Nov 2024 10:21:53 +0000
Transferring Orders Fills from Rithmic To Denali
View Count: 142
[2024-10-05 14:34:38]
User288938 - Posts: 35
Recently I've been experimenting with Prop Firms using Rithmic for order Routing. I still use Denali and have 2 separate installations for SC and have no issues so far.
I do all my charting and analysis on the first instance of SC and just alt tab to the second instance to execute.
Is it possible to transfer the Trade activity log from Rithmic to Denali Symbols and have the fills show up on the first instance of SC?
I've tried exporting the Rithmic trade activity and writing a python script to adjust all the values and such. I thought it would be easier to transfer the trades to a sim account. I've attached the file below, when i go to import the file though, the order fills are not showing up on the chart. I can only assume I've done something wrong and have missed a small detail - Could someone have a quick look at my edits and see what the problem might be or if theres an easier way to transfer order fills?
Cheers
attachmentTradeActivityLog_Updated_Version.txt - Attached On 2024-10-05 14:33:01 UTC - Size: 3.84 KB - 48 views
[2024-10-07 13:54:23]
John - SC Support - Posts: 36203
We are able to import the fills from your file just fine. Are you not able to get the fills to show in the Trade Activity Log?
[2024-10-07 14:03:31]
I can import fine and they show up on the log, but im trying to get them to show up on the actually chart when when you turn fills on. I thought by changing the account and symbols in the text files it would work but maybe im missing something to update?
[2024-10-07 16:05:48]
Since the fills are in the log and are associated with the Sim1 account, you should be fine to display them in the chart. Refer to the information at the following link for the things to check:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2024-10-08 01:05:15]
Hey,
Sorry the logs are actually associated with Rithmic, I exported the trade logs from my rithmic account and tried to change the values to get them to match exported sim trades if that makes sense. So the file i uploaded was the end result but the order fills are still not showing on my chart.
as an example; I changed the symbols from MCLX24.NYMEX to [sim]MCLX24_FUT_CME as well as the trade account to 'sim1'
Are there any other values that I need top adjust in order to get the Rihtmic trades to show up on my denali account? And just to clarify I am exporting and importing across instances as Im running 2 instances of SC
[2024-10-08 14:05:19]
From the file you sent, the information in the file is fine. If you are able to import the data into the Trade Activity Log and the log shows the fills, then that part is fine and the fills are now listed in that instance. From there, if the order fills are not showing on your chart, then you need to review the information given in the link in post #4.
[2024-10-09 00:38:47]
Hey,
I got it to work. There was an error in my script and the symbol wasn't exactly right.
Sorry to trouble you mate! Appreciate your help
