Date/Time: Fri, 22 Nov 2024 10:04:56 +0000
[User Discussion] - Numbers Bars price custom display
View Count: 182
[2024-10-05 12:13:31] |
lmahonefutures - Posts: 2 |
So, I had question about if I'm able to change the display on the 3rd column where I have price displayed. I would only like to show the last two numbers of the price for ES, so I can know if its a quarter point - 3 quarter points more easily without expanding the zoom. I like to have a certain number of candles displayed for my strategy. For this it's in the 3rd column. Is anybody able to help me out? Is this something I can code in or is this just going to have to be the way it is? |
Attachment Deleted. Capture.PNG / V - Attached On 2024-10-05 12:12:45 UTC - Size: 415.15 KB - 46 views |
[2024-10-07 13:47:56] |
John - SC Support - Posts: 36203 |
The only option is the following, but this is going to affect all the displayed values: Numbers Bars: Volume Display Multiplier For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-08 22:59:46] |
Is this something I can code through ASCIL? To have that volume display modifier only affect the 3rd column in this instance?
[2024-10-09 14:03:17] |
This is not available through ACSIL.
