Date/Time: Fri, 22 Nov 2024 11:43:56 +0000
Missing data during replay
View Count: 121
[2024-10-05 11:58:45]
sadramistes - Posts: 11
Hi, when i try to replay the previous day i get missing data in some of my charts making it unable to use this SC feature. How can i fix this problem? All data have been loaded before i press replay.
Last time i used the replay function was a year ago and it was working fine at that time.
Thank you
[2024-10-05 16:37:39]
Sierra_Chart Engineering - Posts: 17143
If there is missing data, refer to:
[2024-10-08 22:14:46]
The data are missing only during the replay mode. What can i do in this case? Follow the same steps as the link you provided?
Thank you
[2024-10-09 14:01:55]
John - SC Support - Posts: 36203
It is not possible for data to be missing during a replay if the data is there prior to the replay. Why exactly do you state that the data is missing during the replay? What exactly is occurring?
[2024-10-10 08:22:35]
I tried again today and it seems that is working perfectly. Probably it was something on my end. Thank you for your time and your promted responses.
